Thread: Edgesurf into Viz problem
    2010-04
    Default Edgesurf into Viz problem
    I know I'm doing something stupid, but I can't figure it out. I have an Autocad drawing that has an edgesurf in it. When I link or import into Viz 2008 (dwg saved as 2007) the wireframe mesh appears until I try to map it or modify it in any way, then it disappears. I cant get the faces to show as surfaces. What am I doing wrong?
    I could stop if I wanted to loydg's Avatar
    2007-08
    Denver, CO
    334
    Default Re: Edgesurf into Viz problem
    Holy backface culling! It sounds like the faces on the surface are flipped (facing down). This is pretty common with ACAD imports. Try collapsing to Edit Polly or Mesh and select all the faces to flip.
    The geometry will appear fine until mapped. Default materials are one sided and will not show up in the viewport if on the "negative" side of a face. Let us know if that doesn't work.
    Glen Loyd
    Parsons Brinckerhoff Project Visualization
    Lead Design Visualization Specialist
    Autodesk Certified Instructor/3ds Max Design 2012 Certified Associate/Professional
    www.pbprojectviz.com
  1. Replies: 3
    Last Post: 2012-12-10, 01:51 PM
  2. It's not an hours problem - it's a scheduling problem.
    By Paul Munford in forum CAD Management - General
    Last Post: 2012-10-02, 02:29 PM
  3. Zoom problem + dimension & leader problem
    By Mamma Jamma in forum AutoCAD General
    Last Post: 2009-06-16, 07:21 PM
  4. RE: Why can a surface created from edgesurf not be used to slice
    By ronie_ernanto in forum AutoCAD 3D (2007 and above)
    Last Post: 2006-12-08, 04:12 AM
  5. Problem and desperation : Level height problem !!
    By Richard McCarthy in forum Revit Architecture - General
    Last Post: 2004-09-10, 03:04 AM
