Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: One Room Not Visible
  1. #21
    2017-02
    Default Re: One Room Not Visible
    Had the same problem, many rooms would not display.
    Found the "Limit offset" by mistake was 32000mm instead of 3200mm and the room will not display correct if it collides with one or more rooms on other floor levels.
    The sollution was to set up a schedule with room data incl. "Limit offset" and simply go through all of them to correct the height.
    Hope this information can help some of you out there
    Henrik
  2. #22
    2002-04
    3
    I'm relatively new to Revit, and had a similar problem today, but with visibility of a room in a section view.
    The problem was that unlike the other rooms that were visible in the section, the offending room was not bounded by walls. It was visible and could be tagged in plan, and I had set the limit and base offsets correctly in properties, but it was not visible in section.
    It seems like the solution is to not use floating "unbounded" rooms, in order to see the room in section. (my excuse for using an unbounded room: this particular "room" is an industrial tank linked from another model, and I wanted control over naming of the "room" for my tag. In an ideal world rooms would be coordinated across disciplines, but no time on this project.)
  3. #23
    2012-07
    I know this thread is a few years old, but I also had this issue using Revit 2020, I tried all the ideas mentioned with no luck. What did resolve it was the skirting boards we had put into the room (as a wall with a sweep) were room bounding, once that was switched off the room appeared in plan..
    Quote Originally Posted by k-braithwaite723808 View Post
    I HAD THIS PROBLEM WITH ROOMS VISIBLE IN SECTION BUT NOT IN PLANS.
    I CHECKED....
    • WORKSETS
    • PHASE
    • ROOMS TICKED IN VIEW TEMPLATE (VT)
    • VIEW RANGE
    • HIDDEN IN VIEW (LIGHT BULB)
    • OVERRIDES
    • PLAN REGIONS
    • FILTERS
    • MAKE NEW PLAN (NO VT) AND CHECK IF IT'S VISIBLE THERE
    • OBSCURED BY ANOTHER ELEMENT (EG. MASS OR FLOOR)
    • DESIGN OPTIONS
    AND YOU'LL NEVER GUESS WHAT IT WAS....
    TWO ROOM SEPERATION LINES WERE IN THE SAME PLACE ON TOP OF EACH OTHER. I DELETED ONE, AS I WAS TIDYING THE MODEL AND THE ROOM APPEARED IN THE PLAN. I DON'T UNDERSTAND WHY THIS WORKS, BUT IT DID.
    I HOPE THIS HELPS! I WAS READY TO THROW MY COMPUTER OUT THE WINDOW, AS SUGGESTED ABOVE.
  1. 2014: Room Boundaries visible on floors below
    By jcflynn83600105 in forum Revit Architecture - General
    Last Post: 2015-02-26, 03:59 PM
  2. 2013: Linked Room Tags not visible
    By trialbyfire in forum Revit Structure - General
    Last Post: 2012-10-12, 05:56 PM
  3. Room tags not visible in paper space
    By Jamord00 in forum ACA General
    Last Post: 2008-01-11, 04:09 PM
  4. 8.1/E Room Tag lines to be visible when 'Not enclosed' -O
    By Damo in forum Revit Architecture - Wish List
    Last Post: 2005-12-02, 02:06 PM
  5. Room names visible in sections
    By jwilhelm in forum Revit Architecture - Wish List
    Last Post: 2004-12-03, 11:50 PM
