Results 1 to 8 of 8
Thread: North arrow, nested in a View Title, getting the "N" to rotate
    2001-12
    1,714
    Default North arrow, nested in a View Title, getting the "N" to rotate
    I have a north arrow nested in our view titles, and visible for all plan views, with a parameter to control the True North deviation. I had to make the rotation happen in the nested north arrow, and I am unable to get a little "N" to rotate as well. Of course we are used to (in Acad and Revit) having that little N there and we do a manual rotate, and all is fine. But I seem unable to get the same behavior with the nested component. I started with just a piece of text, but that doesn't work because the text has no meaningul references to align with. So I tried the text in a Generic Annotation, nested in the North Arrow generic annotation, nested in the View Title. I can align and lock the N, but when the ref line rotates the constraints blow up.
    Anyone have any suggestions?
    Thanks!
    Gordon
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: North arrow, nested in a View Title, getting the "N" to rotate
    Just a guess, but try setting up the rotation parameter / reference line in the view title family, rather than in the generic annotation family, and then align lock the generic annotation family to that.
    2006-08
    636
    you don't have to add ref line, for unknown reason, you cannot lock nested text annotation to ref line, you can just add angle parameter directly w/o using ref line.
    2008-08
    Atlanta, Ga.
    95
    is your "Keep Readable parameter turned on in the family?
    http://www.perrycrabb.com/may-the-no...w-be-with-you/
    2008-11
    Australia
    754
    The solution is quite simple, I talked with Gordon about this, but I will add it here.
    Make a generic annotation component with your text and north arrow artwork inclusive.
    Insert the annotation family into your title block, and add a reference line.
    Align and lock your generic annotation to the reference line.
    Angular dimension to the reference line, and to the perpendicular component of your arrow detail item.
    Add a parameter and assign it to the dimension line and name it whatever you like.
    "North Point" for example.
    Group it under dimensions and make it a type parameter.
    You may also want to add an on/off toggle to it, because you won't need the arrow on every sheet (like details for example). So add another parameter under graphics, and name it "North on/off" or whatever you want really. This is an instance parameter.
    2004-12
    New Jersey
    179
    karalon10
    Are you talking about a Title Block and NOT a View Title?
    I've been trying to figure this out for a while and can not get it to work inside a View Title family. I get the same error Gordon was talking about, the constraints blow up.
    Do you have an example to post?
    2006-08
    636
    see attached, as i said before, do not use ref line even though i don't know why, maybe someone or factory can explain it.
    2008-11
    Australia
    754
    I totally mis-read the OP's intent, yes I am referring to titleblock with a north point, my apologies.
    I don't have 2011 version so I can't take a look at the one supplied above but if anyone can give out a 2010 version I'll take a look.
  1. 2014: "split surface" and "paint" in nested family
    By mellacquamarco685726 in forum Revit Architecture - General
    Last Post: 2015-01-13, 10:59 AM
  2. 2012: View title with rotatable north arrow?
    By kdtbird in forum Revit MEP - General
    Last Post: 2013-07-11, 01:23 PM
  3. Replies: 10
    Last Post: 2010-03-11, 12:49 PM
  4. View Title - North Arrow Bearing Control
    By cek in forum Revit Architecture - General
    Last Post: 2008-11-06, 09:55 PM
  5. "True North Arrow" and a "Plan North Arrow
    By gregcashen in forum Revit Architecture - Wish List
    Last Post: 2007-01-17, 12:11 AM
