Thread: Tips and Tricks
    2003-12
    2
    Default Tips and Tricks
    I am preparing some lunch time training events at my office. They include Sheet Sets/Fields, Tool Palettes, Tables and Tips and Tricks. The Tips and Tricks seem to be the hardest to prepare for. The reason is I don't know what people don't know! The following is a list I came with that include mostly commands I brought home from the instructors at AutoCAD University 2004. I would hope that some of you out there could just brainstorm some of your most favorite and obscure commands to add to my list.
    ASSIST
    Opens quick help in the info palette, which provides context-sensitive information
    WHOHAS
    Displays ownership information for opened drawing files
    OPTIONS/DRAFTING/OBJECT SNAP OPTIONS/IGNORE HATCH OBJECTS
    Setting for snapping to hatching
    COPY VIEWPORT
    Copy viewport frame from one drawing to another and maintain integrity of the view
    TEXTTOFRONT
    Brings text and dimensions in front of all other objects in the drawing
    EDGEMODE
    Controls how the trim and extend commands determine cutting and boundary edges
    CTRL+0
    Clean screen - clears the screen of all user interface items exceptthe menu bar and the status bar
    PEDITACCEPT
    Eliminates the prompt “do you want to turn it into one ?<y>” that occurs when you select a non polyline object
    EXOFFSET
    Current - this command allows you to offset objects to the current layer instead of the same layer as the original object
    Multiple - this command allows you to offset multiple times without reselecting the object to offset
    MTEXT
    To save your changes and exit the multiline text editor click ok, left click in the drawing outside the editor or press ctrl+enter
    EXPRESS/MODIFY/DELETE DUPLICATE OBJECTS
    Deletes duplicate objects, lines, arcs and polylines
    YE
    You can use this macro to erase the objects on a selected layer
    LAP
    You can change the color and linetype of a layer without going into the layer manager
    UTILITIES/OBJECT INSPECT
    You can view text information associated with any object in a drawing
    TRIM/EXTEND FENCE
    Trim or extend multiple lines at once
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,447
    Default Re: Tips and Tricks
    One that I use quite a bit is the pline-line-length command when drawing road centerlines to make sure the tangents coming out of a curve are really tangent to the arc. Start the pline command, draw a line, then a for arc, pick the endpoint then type L for line and type L again for the length.
    All AUGI, all the time BCrouse's Avatar
    2003-04
    Bethlehem, PA
    980
    Question Re: Tips and Tricks
    Quote Originally Posted by mrenfrow
    ASSIST
    WHOHAS
    COPY VIEWPORT
    TEXTTOFRONT
    EDGEMODE
    CTRL+0
    PEDITACCEPT
    EXOFFSET
    MTEXT
    YE
    LAP
    TRIM/EXTEND FENCE
    Do you have the macros for these tip and tricks
    I could stop if I wanted to JASONM30395's Avatar
    2002-04
    Halifax NS Canada
    397
    I've found that you should probably go over the basics every year or so just because if anyone doesn't know them they won't admit to it. It also helps to keep a database of what you've gone over and how long ago.
    If you want to get downright technical turn on everybody's logfile and see what commands they do use so you can concentrate on the ones they aren't
    Loyalty above all else except honor
    For my honor is my life!
  1. Tips & Tricks
    By jca10aps in forum NavisWorks - General
    Last Post: 2012-05-31, 03:20 AM
  2. Tips & Tricks PDF
    By andy.manninen in forum AutoCAD Tips & Tricks
    Last Post: 2007-02-16, 04:58 PM
  3. Tips and tricks?
    By Archman in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-11-06, 07:09 PM
