How can I Scale 2 Different Objects in the Same ModelSpace.( Ex. One Object 1/4" =1' & 1/8"=1' .) Or Different ModelSpace for Different Viewport?
I think a more complete answer would be: You need to use objects that are setup to use annotation scaling. Such as a block with that property turned on. Then you insert the block and add/remove the required scales.
Then the two different viewports answer makes sense.
R. Robert Bell
Design Technology Manager
Stantec
