Results 1 to 6 of 6
Thread: Architect's light fixtures don't show dark [2009]
    AUGI Addict matt__w's Avatar
    2002-06
    North Central CT
    1,108
    Default Architect's light fixtures don't show dark [2009]
    I've got an architectural model that is linked into our MEP mode. We're using the architect's light fixtures on our lighting plans. In VG, I have the halftone toggled on for the link. The discipline for my view is set to electrical. The few light fixtures we have in our model show up dark; the architect's are showing up haltfone. What's the deal? Do I have to modify their model and change their discipline to electrical?
    Matt
    Certifiable AUGI Addict cliff collins's Avatar
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: Architect's light fixtures don't show dark [2009]
    I believe if you "halftone" the entire Linked Arch. model, then the lights will be
    halftoned.
    Try going to VG and Custom setting, and changing the light fixture category in the linked Arch. model.
    cheers
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    I could stop if I wanted to gvluisi's Avatar
    2009-05
    Pittsburgh, PA
    245
    Default Re: Architect's light fixtures don't show dark [2009]
    Maybe the category of their fixtures are not "Lighting Fixtures".
    Edit: What Cliff said
    Last edited by gvluisi; 2010-09-14 at 07:45 PM. Reason: failure to read previous post entirely
    2009-05
    Pittsburgh, PA
    245
    What I really meant to say was Edit the Family (of the Arch's Lite) and change the category there.
    2002-06
    North Central CT
    1,108
    Just wanted to follow up...
    The arch's light fixtures are actual light fixtures. Apparently half-toning the entire link also affects the electrical stuff (even though the discipline is set to electrical). What we ended up doing was going into VG for the link and overriding the color there and set everything (except for light fixtures) to gray and beefed up the lineweight for light fixtures to match our settings. Kind of a pain, but in the end the result is what we wanted.
    Matt
    2003-06
    Manchester, NH
    222
    If you don't set the link to half tone, and don't manually change the architectural things to half tone, the view discipline should handle most of this for you.
    All items that aren't considered "MEP" items automatically draw as "underlay" in MEP views.
  1. 2015: CUI Images - Dark & Light
    By sbrennan in forum AutoCAD CUI Menus
    Last Post: 2015-02-11, 05:21 PM
  2. 2014: Light + Dark Active Theme while Worksharing
    By Limbatus in forum Revit Architecture - General
    Last Post: 2014-07-08, 07:02 PM
  3. Pendant Light Fixtures and Light Sources
    By heiko.stugg in forum Revit MEP - Families
    Last Post: 2011-01-31, 12:25 PM
  4. 2009 Light Fixtures
    By SCShell in forum Revit Architecture - General
    Last Post: 2009-03-04, 02:42 PM
  5. Architect's Plumbing Fixtures
    By RevitNinja in forum Revit MEP - General
    Last Post: 2008-05-27, 03:47 PM
