Hello everyone,
I am abit puzzled about what's going on and Civil 3D 2011 is still so slow on a
Core i7 930 cpu (thats 8 bloody cores! I guess thats 4 cores x2 due to hyperthreading??)
with 6GB or RAM
and Nvidia Quadro FX 1800
and even with an 80GB SSD....
OK I am working on a Tin surface here - about 3km of road. This is just the surface here no extra layer. so its just triangles, contours, points.
when i extract ALL the objects (about 250k of them - yes that's alot) it takes ages to complete each operation.
In fact, the operation: extract from surface -> select all objects BUT the surface -> copy them -> create new file -> paste to original location
took enough time, for me to find this website, register, and write this post..!!!!
Whats puzzling me, is that while checking the resource monitor in windows 7, I was astonished to see that the whole command is run by just one of the 8 cores. only one would look as if its carrying out some intensive operation.. and the acad.exe process would only show total cpu usage of 12%..
Additionally the GPU seems only to be used when I run the commands like '3d orbit' - at least then the image rotation is smooth.
however, i didn't do that here, and the gpu , along with 7/8 cores seem to just be lazy...
and i don't want that.
(note: I should also mention that the memory used in total by the system is no more than 4GB so it's not like the RAM is slowing down the processing)
so there is one of three things to conclude here:
1) either i am missing a driver or smth that will let civil 3d utilize all cores (and perhaps the gpu too since Quadro cards can be beasts of parallel calculations)
2) Civil 3d as an application fails to incorporate multi-core CPU and GPU programming to allow it to run faster. That would be most upsetting since you get to pay such large sum of money to use this application
3) impose restrictions in my project to get the job done, like reduce the area of the surface or the density of the objects etc. Also not a great idea since I paid the extra money to get a workstation level computer in order to EXACTLY avoid doing that...
If however the problem can be fix, could you give me any pointers??
Thank you very much vfor your help
Thanassis Silis
