We would like to show the CFM in plan on our VAV boxes, 500 CFM as a tag. Do we need to make another tag that can display this info? Is this possible? See attached
Quick solution would be to create a tag for the Airflow of the Duct just as it leaves the VAV box (Flow is already a shared parameter in ductwork)
"Correct" solution would be to create Flow as a shared parameter within the VAV family and then you can tag (and schedule) it. Within equipment though remember there will be many different types of flow to specify - Supply, Return, Exhaust, Outside Air, Chilled Water, Heating Water - etc etc
