Results 1 to 10 of 16
Thread: modified "Polygon" command
    2007-10
    Arlington, TX
    20
    Default modified "Polygon" command
    I am trying to come up with a modified "polygon" command.
    What I need:
    -always 12 sided
    -always circumscribed about circle
    -enter diameter instead of radius (std is to enter radius)
    I am fairly new to lisps, and thanks for your help in advance.
    This is what i have so far:
    (defun cg12 () ;
    (SETQ pgpt1 (getpoint "\Specify center of polygon: "))
    (command "polygon" "12" pgpt1 "c")
    (princ)
    Earth
    9,823
    Default Re: modified "Polygon" command
    Here is one way...
    (defun c:g12 ()
      (vl-cmdf
        "._Polygon"
        "12"
        "_C"
        (* (getreal "\nEnter diameter: ") 0.5)
    (princ)
    R.K. McSwain | CAD Panacea |
    2010-06
    962
    Here is another way and with the same result .
    (defun c:g12 (/ dia cen)
      (if (and (setq dia (/ (getreal "\nDiameter of Polygon :") 2.0))
    	   (setq cen (getpoint "\nCenter of Polygon :"))
      (vl-cmdf "_.polygon" 12 cen "_c" dia))
      (princ)
    Tharwat
    2007-10
    Arlington, TX
    20
    Thanks. Both of them worked, its always good to see different ways of coming up with the same result. I appreciate the help.
    2008-02
    1,141
    Quote Originally Posted by tharwat313 View Post
      (princ)
    Tharwat
    Remove possible errors...
    (defun c:g12 (/ p d)
      (if (and (setq p (getpoint "\nSpecify center of polygon: "))
               (not (initget 6))
               (setq d (getdist "\nSpecify diameter of polygon: "))
        (command "_.polygon" 12 "_non" p "_c" (/ d 2.))
      (princ)
    2010-06
    962
    Quote Originally Posted by alanjt View Post
               (not (initget 6))
      (princ)
    ِAbsolutely right.
    With my codes if user hit <enter> I mean without a value, it would give the following error.
    ; error: bad argument type: numberp: nil
    But with your codes, it would exit calmly.
    Thank you so much Alanjt.
    Greatly appreciated.
    Tharwat
    2010-06
    962
    Mr. Alanjt.
    Would you please give us an example of making this small routine the same way that we insert a block with the command insert ?
    For example:
    First enter the dia.
    Second insert the polygon the same way you insert a block.
    I would like to get that kind of technique from you.
    Thanks.
    Tharwat
    2008-02
    1,141
    Mr. Alanjt.
    For example:
    Thanks.
    Tharwat
    Just reverse your prompts...
    (defun c:g12 (/ d p)
      (initget 6)
      (if (and (setq d (getdist "\nSpecify diameter of polygon: "))
      (princ)
    2010-06
    962
    Thanks.
    But that wasn't what I meant. something like using the function grread or so.
    2008-02
    1,141
    Thanks.
    I don't understand. You've specified the insertion point, size and number of segments. There's nothing else one could do. Are you wanting to use grread to place and/or set size of polygon?
  1. 2016: Why Autocad has "None" option in "UNDO" command?
    By MTGH9UU in forum AutoCAD General
    Last Post: 2015-09-14, 03:27 PM
  2. Replies: 8
    Last Post: 2012-08-18, 01:31 AM
  3. HOW switch COMMAND "BLOCK" THE "Scale Uniformly"
    By viz_ken1030 in forum AutoLISP
    Last Post: 2006-11-17, 12:41 PM
  4. "Modified Linked File"?
    By dbaldacchino in forum Revit Architecture - General
    Last Post: 2006-06-21, 06:06 PM
  5. Replies: 3
    Last Post: 2006-03-23, 10:25 PM
