Thread: ACAD 2011 Structural Detailing SP1 or ACAD 2011 Update 1.1??
    2007-12
    75
    Default ACAD 2011 Structural Detailing SP1 or ACAD 2011 Update 1.1??
    Ok, so I sent an error report when my AutoCAD crashed the other day & it recommended I install AutoCAD Structural Detailing 2011 Service Pack 1...then I was browsing the Autodesk website & noticed there was also an AutoCAD 2011 update 1.1. Does anyone know which one I should install? Or if both? Autodesk is confusing this year because they refer to ACAD 2011 as ACAD structural detailing this year...even when you open ACAD 2011 it calls it that even though there is a seperate shortcut for structural detailing. Wasn't sure if update 1.1 was a prerelease of the service pack 1 or came after or what? Just trying to get my CAD software up to date. Thanks
    2000-01
    Seattle WA USA
    5,859
    Default Re: ACAD 2011 Structural Detailing SP1 or ACAD 2011 Update 1.1??
    AutoCAD Structural Detailing is a vertical based on AutoCAD. So you need to install the update specifically for that vertical and not the "vanilla" AutoCAD update.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2015-12
    2,095
    This general question ("Why can't I install the AutoCAD SPnnn on my run-as version?") seems to come up an awful lot. Might be worth being a sticky somewhere, such as under the vertical application areas. A brief explanation that only "genuine" AutoCAD can use the AutoCAD service packs while verticals, including the "run-as AutoCAD", will need the update specific to the parent vertical.
  1. Cannot view ASD 2011 in ACAD 2011 when selecting work spaces
    By dm3 in forum AutoCAD Structural Detailing
    Last Post: 2011-04-05, 07:27 PM
  2. Help using Acad of ASD 2011
    By tuanlong.hau in forum AutoCAD Structural Detailing
    Last Post: 2010-10-25, 02:28 AM
  3. ACAD MEP 2011 pipes not showing in Navis 2011
    By whodgins in forum NavisWorks - General
    Last Post: 2010-08-31, 04:17 PM
  4. AutoCAD® Structural Detailing 2011 - What's New Video Tutorials
    By abbakeer in forum AutoCAD Structural Detailing
    Last Post: 2010-04-16, 12:35 AM
