Results 1 to 10 of 14
Thread: Volume of Solids
    2009-11
    51
    Question Volume of Solids
    Hey everyone,
    Anyone know of a command that can calculate volumes of 3d shapes?
    Thanks for any help!
    2009-11
    5,743
    Default Re: Volume of Solids
    Try this:
    (defun c:3DVOL (/ eName 3dObj)
      (vl-load-com)
      (if (and (setq eName (car (entsel "\n  >>  Select 3D Object for Current Volume: ")))
               (= "3DSOLID" (cdr (assoc 0 (entget eName))))
               (vlax-property-available-p
                 (setq 3dObj (vlax-ename->vla-object eName))
                 'volume))
        (princ
          (strcat
            "\n  <!>  3D Volume = "
            (rtos (vla-get-volume 3dObj) 2 2)
      (princ))
    Last edited by RenderMan; 2010-09-28 at 04:31 PM. Reason: Renamed the command from c:FOO to c:3DVOL
    Computer Specs:
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    2009-11
    51
    Question Re: Volume of Solids
    So....anyone know of another way to find the volume of 3D shapes!?
    2009-11
    5,743
    Quote Originally Posted by William.Gares View Post
    Did you try the command I provided you?
    Computer Specs:
    2009-11
    51
    No, what exactly are you recommending I type in the command box????
    2009-11
    5,743
    I've provided you a LISP routine, which when loaded into AutoCAD provides you a keyboard command that does exactly what you want.
    To make this a little easier for you, I've uploaded a .LSP file that you can download, and have renamed the command from FOO (a common test function name) to 3DVOL (what you should enter at the command line shortly).
    For starters, I'd like you to test the routine to make sure you understand it's use, and if you want to keep it (this is your decision), I'll gladly help you make it available to you at all times.
    So to make the 3DVOL command available, open AutoCAD, and drag the downloaded file (from Windows Explorer) into your drawing area (either in Modelspace, or Paperspace, i.e., Not on a toolbar, etc.). Then enter 3DVOL at the command line and hit Enter... follow the prompts.
    Computer Specs:
    2009-11
    51
    Ok, I drug the file from my desktop into the model space. It verified it was loaded in the command box. Once I typed "3DVOL" it prompted me to "select 3D object for current volume". Once I selected the object no other prompts were given.
    2009-11
    5,743
    OK, that mean that either the object you selected is not a "3DSOLID" or the property test failed.
    Would you be willing to post a sample drawing for the object you selected for me (save as 2007 File format)? Then I can see exactly what entity you're working with.
    Computer Specs:
    2009-11
    51
    Sure...hope this helps. It gave me some trouble saving to 07, not sure how much of this is compatible. I am working with Civ 3D 2010.
    2009-11
    5,743
    The routine works for me, William.
    I've revised the code to permit selecting multiple 3DSOLID's, and returning a Total Volume.
    Enjoy!
    Computer Specs:
  1. Select/Delete solids by volume.
    By p.bakardjiev in forum AutoLISP
    Last Post: 2023-06-29, 02:08 PM
  2. Volume from solids
    By Wish List System in forum NavisWorks - Wish List
    Last Post: 2016-12-07, 11:25 AM
  3. 2015: Répercussion d'un paramètre partagé de matériaux d'un volume vers ses sols de volume
    By eric.lehy-meira695599 in forum Revit Architecture - General
    Last Post: 2015-04-22, 10:25 AM
  4. Volume of solids?
    By patricks in forum Revit Architecture - Families
    Last Post: 2006-08-24, 02:31 PM
  5. Fields for mass and/or volume of 3D Solids
    Last Post: 2006-02-07, 07:35 PM
