Thread: Pipe fitting annotation size
    2010-07
    16
    Default Pipe fitting annotation size
    I am trying to alter the pipe fitting annotation size from the standard 3.0 to 2.0. When I altered the default value Revit set it to zero, and will not allow me to enter a number into the value field. Is this a fault in the program? The pipe fittings are smaller than when set to the default 3.0; in fact they are too small. Any experience with this issue? Is there a better way I can control fitting size and for that matter 2D single line pipe visibility settings?
    2009-06
    Missouri
    112
    Default Re: Pipe fitting annotation size
    You might try checking Manage tab --> Project Units --> Common --> Length and make sure the rounding hasn't been changed to a level that would round your 3.0 or 2.0 down to zero.
    2010-07
    16
    Genius! That fixed it. I had changed the rounding as a lazy way to control duct sizing.
  1. Pipe fitting size TAG
    By Happyunited in forum Revit MEP - General
    Last Post: 2011-10-10, 05:24 PM
  2. Pipe Fitting and Accessories halftone an half size
    By bhanna888349 in forum Revit MEP - General
    Last Post: 2011-09-19, 09:32 PM
  3. Pipe Size changes Fitting
    By cdsuggs in forum Revit MEP - Families
    Last Post: 2010-07-26, 09:32 PM
  4. Reducing Pipe Fitting Sizing Issue Based on Pipe Size
    Last Post: 2010-07-22, 08:06 PM
  5. Size of Single Line Wye Pipe Fitting
    By i2mikee in forum Revit MEP - General
    Last Post: 2010-07-13, 08:11 PM
