Results 1 to 8 of 8
Thread: Saving turns my file to Read Only - Help
    2010-09
    2
    Default Saving turns my file to Read Only - Help
    Everytime I go to save or do a saveas, my file turns into a Read-Only file type. However, if I close and re-open the file, it is no longer a read-only. But, then when I go to save after a few minutes, it will turn back into read-only. Help!
    2000-01
    Seattle WA USA
    5,859
    Default Re: Saving turns my file to Read Only - Help
    What kind of network are you on?
    R. Robert Bell
    Design Technology Manager
    Stantec
    2010-09
    2
    it's just me...my personal computer
    Earth
    9,805
    Ok, not that is should matter, but what O/S?.... what version of AutoCAD?.... is this vanilla AutoCAD or a vertical?.... are the drawings stored on the "C" drive, or a removable HDD, or a flash drive, etc.?.... any other info?
    R.K. McSwain | CAD Panacea |
    2010-07
    Hey
    I am facing the same problem.
    I am using Civil 3d 2011 and OS Windows XP
    Is there any solution on this
    2010-02
    6
    I C theres been no solution posted...I have user with same problem...anybody solve it or did it go away. I asked the same question about working on usb drive or other drive other than "C" but nothing yet.
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Read Only occurs when one of three things happen:
    1.) You don't have permissions to edit the file from that location.
    or
    2.) The file is already open by someone other than you or in a different session of CAD.
    or
    3.) When another application is accessing the file but it's not necessarily open in AutoCAD Examples: a "block library" program is allowing you to view a preview image of the file or it is currently being copied from one location to another) .
    Technically a virus scanning program could also cause it by not allowing changes to the files in a specific directory.
    I know, not exactly an answer, but these are areas to investigate as each situation can be different.
    All AUGI, all the time Liamnacuac's Avatar
    2016-01
    Earth
    508
    The anti-virus thing would be my suspicion. Be sure to have all autocad files on your "do not check" or low priority list, whether at home or on a network. This includes the .DWG, .DWF, .AC$, .LSP (although lisp routines can have viruses, yet I don't think anti-virus software would know what kind of code to look for. I may be wrong about that), and .bak.
    Having said that, we have a viruse here. It alters acad.lsp and acaddoc.lsp to create another file( acadapg) for accounting purposes. like most viruses, it isn't terribly malicious, it just creates a bunch of useless files you have to purge.
  1. 2014: AutoCAD & CADWorx Plant keeps saving as read only
    By beekermail130534 in forum AutoCAD P&ID - General
    Last Post: 2015-05-19, 02:27 PM
  2. Read File from text file to restore settings
    By dilek in forum AutoCAD Customization
    Last Post: 2013-04-22, 12:47 PM
  3. Open Read-Only: The ability to open a worksharing enabled file in a read only mode.
    Last Post: 2012-09-05, 07:02 PM
  4. Saving as 'Read Only'
    By Spenner in forum AutoCAD General
    Last Post: 2010-02-05, 08:31 PM
  5. Open read only turns into actual live drawing
    By Steve_Bennett in forum AutoCAD General
    Last Post: 2007-04-24, 08:34 PM
