Thread: Tips and Tricks
    2003-12
    2
    Default Tips and Tricks
    I am preparing some lunch time training events at my office. They include Sheet Sets/Fields, Tool Palettes, Tables and Tips and Tricks. The Tips and Tricks seem to be the hardest to prepare for. The reason is I don't know what people don't know! The following is a list I came with that include mostly commands I brought home from the instructors at AutoCAD University 2004. I would hope that some of you out there could just brainstorm some of your most favorite and obscure commands to add to my list.
    ASSIST
    Opens quick help in the info palette, which provides context-sensitive information
    WHOHAS
    Displays ownership information for opened drawing files
    OPTIONS/DRAFTING/OBJECT SNAP OPTIONS/IGNORE HATCH OBJECTS
    Setting for snapping to hatching
    COPY VIEWPORT
    Copy viewport frame from one drawing to another and maintain integrity of the view
    TEXTTOFRONT
    Brings text and dimensions in front of all other objects in the drawing
    EDGEMODE
    Controls how the trim and extend commands determine cutting and boundary edges
    CTRL+0
    Clean screen - clears the screen of all user interface items exceptthe menu bar and the status bar
    PEDITACCEPT
    Eliminates the prompt “do you want to turn it into one ?<y>” that occurs when you select a non polyline object
    EXOFFSET
    Current - this command allows you to offset objects to the current layer instead of the same layer as the original object
    Multiple - this command allows you to offset multiple times without reselecting the object to offset
    MTEXT
    To save your changes and exit the multiline text editor click ok, left click in the drawing outside the editor or press ctrl+enter
    EXPRESS/MODIFY/DELETE DUPLICATE OBJECTS
    Deletes duplicate objects, lines, arcs and polylines
    YE
    You can use this macro to erase the objects on a selected layer
    LAP
    You can change the color and linetype of a layer without going into the layer manager
    UTILITIES/OBJECT INSPECT
    You can view text information associated with any object in a drawing
    TRIM/EXTEND FENCE
    Trim or extend multiple lines at once
    2003-10
    706
    Default Re: Tips and Tricks
    We have an intranet site with all of our standards on it and I've placed a tips and tricks section in it that also includes common problems and their fixes. Things like why hatch patterns appear scattered or the solid hatch doesn't work and things to look out for and check when complex linetypes appear wacky. Stuff like that. Believe me, this cuts down on a lot of the same questions asked almost every day and we also invite suggestions to the site if someone gets something weird happening and they come up with a solution. Just a thought.
    2015-12
    Arizona
    2,337
    If not real busy, search the Forums for some of the
    good stuff from the Land Desktop gang.
    I'm sure there are some nuggets in there worth sharing.
    I could stop if I wanted to dfarris75's Avatar
    2004-12
    where ever i'm at
    252
    a couple i tend to share with friends and others in my office are maxsort and pickfirst. i have one friend that i have to tell pickfirst to every few months because he forgets it.
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,430
    One that I tend to use alot is in the PLINE command, to assure that a tangent is truly tangent to a curve, after you issue the pline command, type A for arc, draw your arc and then type (or right click) and select L for Line and then type L again for length. This will draw a tangent line from the end of the arc at the length specified, either by cursor input or at the command line. Watch for OSNAPS though.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
  1. Tips & Tricks
    By jca10aps in forum NavisWorks - General
    Last Post: 2012-05-31, 03:20 AM
  2. Tips & Tricks PDF
    By andy.manninen in forum AutoCAD Tips & Tricks
    Last Post: 2007-02-16, 04:58 PM
  3. Tips and tricks?
    By Archman in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-11-06, 07:09 PM
  4. Tips and Tricks
    By mrenfrow in forum Civil 3D - Civil Design Companion - General
    Last Post: 2005-02-15, 05:49 PM
