Thread: AutoCAD 2010 layer issue
    2008-09
    Default AutoCAD 2010 layer issue
    I am wanting to pick a new layer from the layer drop down area in AutoCAD 2010 but for some strange reason only one layer is showing and not all layers. This happens on and off and is very frustrating. Is this a software glitch or is there a setting somewhere to bring all my layers back? This never happened to me in AutoCAD 2009!
    0,0,0 The Origin
    8,570
    Default Re: AutoCAD 2010 layer issue
    Hi, welcome to AUGI.
    Perhaps you have a layer filter that is applied to the toolbar. Pick the layer manager button that shows a spanner.
    2008-11
    12
    When this has happened to me, it's because the current layer list is a subset. Open the Layer Manager and you see a list of layers. The window on the left will tell you if you are looking at a filter or xref or some other subset (if it's not there, open the Layer Filters pane). Select All Layers. You should see the entire list, and that will carry over to the pull-down list.
  1. Saving Issue Autocad 2010
    By s_saldanha in forum AutoCAD General
    Last Post: 2011-04-18, 05:46 AM
  2. AutoCAD 2010 DWG to PDF TTF Issue
    By jetman in forum AutoCAD Plotting
    Last Post: 2010-08-03, 03:01 PM
  3. AutoCAD 2010 LT lag issue.
    By jshx97 in forum AutoCAD LT - General
    Last Post: 2010-06-15, 12:44 PM
  4. Autocad 2010 Lt ATTEXT issue
    By chris.125833 in forum AutoCAD Customization
    Last Post: 2009-07-24, 11:08 PM
  5. ADT In AutoCAD 2006 - Layer Issue
    By omorah in forum AutoCAD General
    Last Post: 2007-08-15, 04:15 PM
