Thread: Converting Metric to Imperial DWG
    2005-07
    Bermuda
    5
    Question Converting Metric to Imperial DWG
    So I am a happy surveyor collecting data and drafting in METRIC. The client then decides he wishes IMPERIAL to be the end product. Does anyone know how to convert from METRIC TO IMPERIAL?
    2009-03
    8
    Default Re: Converting Metric to Imperial DWG
    The easiest way I've found is to set your coordinate system on the Settings tab to reflect a Metric coordinate system (e.g. metric state plane) and then export all content to LandXML. Create a new drawing and set an Imperial coordinate system before bringing in the LandXML file. This works well for e.g. alignment/profile/point data. For a survey database I would think that the conversion can be handled in the survey database but I am not as familiar with that workflow.
  1. 2014: Converting AutoCAD .pat file from Imperial to Metric
    By kmarquis in forum Revit Architecture - General
    Last Post: 2013-07-26, 10:44 PM
  2. Converting a Survey from Metric to Imperial Units
    By marble in forum AutoCAD Civil 3D - Survey
    Last Post: 2011-11-22, 02:11 PM
  3. Converting file from IMPERIAL to METRIC
    By Openwheeler in forum AutoCAD General
    Last Post: 2008-07-18, 01:06 PM
  4. Converting Imperial to Metric
    By jbrazier in forum Revit Structure - Families
    Last Post: 2007-09-27, 08:05 PM
  5. Converting Downloads from imperial to metric
    By Kelvin in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-01-09, 08:00 AM
