Thread: Plot Window Preview
    2010-08
    3
    Default Plot Window Preview
    In 2010/2011, when I plot in paper space and use the window option, it doesn't show a preview of the last area that was plotted/selected. It does show the preview in model space (See image). Does anyone know how to fix this? Thanks!
    Default Re: Plot Window Preview
    I have seen that in the layout space before but not the model space, this can be solved for layouts by going to options>display>display printable area (tick on or off)
    2015-11
    Jo'burg SA
    4,512
    Firstly ... I prefer not using the window option in PS. Makes it difficult at best to plot multiple drawings.
    That being said, there may be situations when you want to do it temporarily - just DON'T ASSIGN to layout. Please
    What you may be experiencing is the very slight difference in contrast on PS. You'll hardly be able to see the bounding box of the previous window picked - it's there if you look very closely, but it's difficult to see. As NorcoCAD's stated you can't see it if the either / both of the Display printable area and Display paper background is turned on in the Options / Display dialog. The contras used is simply too close to notice on most screens.
  1. 2014: Plot Window - Paper Preview Missing
    By J.A. Mounteer in forum ACA General
    Last Post: 2014-08-21, 02:53 PM
  2. Hatch does not display in Plot Preview or in Plot output
    By davidsears in forum AutoCAD General
    Last Post: 2008-04-11, 10:28 PM
  3. Modelspace objects will not Plot Preview or Plot
    By mhudson in forum AutoCAD Plotting
    Last Post: 2007-05-25, 07:11 PM
  4. Replies: 3
    Last Post: 2007-02-28, 11:00 AM
  5. Setting plot window in plot preview
    Last Post: 2006-04-18, 07:51 PM
