Hello!!
Is it possible to start drawing multileader and its start in a particular layer? So if I am in layer "0" and start multileader, after finishing he is in layer "dim"!?
Thanks
Hello!!
Thanks
The short answer is... Yes.
More specifically, how are you initiating the command... are you using keyboard shortcuts, toolbar buttons, etc.?
If from the toolbar, you could create a custom macro.
I personally use a Visual LISP Reactor:
A :vlr-CommandWillStart callback detects the command entered, and changes the layer prior to beginning the command, and using a :vlr-CommandEnded callback, the layer is set back to the original starting layer.
That sounds like a lot, but it happens near instantaneously.
Hope that helps!
Computer Specs:
The easiest way to make this happen is to create a tool palette command where you can set the properties of the item being created.
* Create a MLEADER in your drawing.
* Drag and drop it on the desired tool palette.
* Right click on the new palette button, adjust the properties as needed.
R.K. McSwain | CAD Panacea |
Computer Specs:
here it is. Most of it is over my head. I knew how to change the parts that pertain to my layer types, and that's about it.
There's a lot of code in that one LISP file.
As to why it is not working for you in 2010/2011....
There could be one (or more) reasons for this to happen. For example:
- The "VLR-Manager" application is loaded without explicitly defining the file path. When deploying the 2010/2011 software, if the application no longer resides within your support search paths, then this would fail immediately. But there should be an error associated, such as:
Code:; error: LOAD failed: "VLR-Manager" _$Hope this helps!
- Next could be any change(s) in your registry settings, as this routine heavily reads for information from the registry.
- The same issue may exist for your linetype(s) being loaded, as the file paths are not explicitly defined.
Computer Specs:
found this as an alternative to Autolay
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6433
