Results 1 to 6 of 6
Thread: Installation Problem
    2009-06
    30
    Default Installation Problem
    I am trying to install a stand alone seat of RAC 2011. I had the trial version installed, and uninstalled it. There was a power outage during the uninstall, which resulted in an incomplete. Now when I try to install, I got the message that Revit 2011 is already installed.
    Is there some file that I need to delete that will allow me to install?
    Thanks
    All AUGI, all the time Munkholm's Avatar
    2006-09
    The Kingdom of Denmark
    560
    Default Re: Installation Problem
    Autodesk has an "How to" right here:
    http://usa.autodesk.com/adsk/servlet...&siteID=123112
    Tried it just the other day with RAC2010, but with no luck - Actually ended up using an old DOS command (Format C)
    Hope you have better luck
    - Klaus Munkholm
    2009-06
    30
    Thanks for the info, but it did not take care of the problem
    Thanks
    2009-06
    30
    Could you please explain how to use the DOS command?
    Thanks
    2006-09
    560
    Guess not everyone is old enough to remember the "good old" DOS commands
    What i meant is, that i ended up formating the harddrive and reinstalling windows - Be 100% sure that you are out of other options before you do that though... it´s very time consuming to go for a fresh install of everything (but also worth it most of the times)
    Sorry the link was of no use - Best of luck.
    - Klaus Munkholm
    2009-06
    30
    Anyone have any ideas other than reinstalling windows?
    Thanks
  1. Installation Problem
    By zanzibarbob7 in forum Revit Architecture - General
    Last Post: 2010-04-15, 10:20 PM
  2. Viz Installation problem
    By bard in forum VIZ - General
    Last Post: 2009-10-16, 03:02 AM
  3. SP1 Installation problem
    By thm291966 in forum AMEP General
    Last Post: 2008-08-19, 03:18 PM
  4. Installation problem
    By AutoTAD in forum Software
    Last Post: 2008-01-04, 02:45 PM
  5. Installation Activation Problem
    By marc1989 in forum Revit Architecture - General
    Last Post: 2007-10-28, 04:59 AM
