Results 1 to 10 of 17
Thread: How to use a different xref and change path?
    2010-02
    5
    Default How to use a different xref and change path?
    Hello, I have to change the xrefs of 400 files. I was wondering if anyone have a fast lisp or programming routine to use.
    Basically we have files named superbuilding1-floor1 found in C:/files/superbuilding1-floor1.dwg but now the file would be called superbuilding1-abc found in Z:files/superbuilding1abc.
    The name of the new xref is very similar so it is possible to use a wild card character like building1* Unfortunately the last parts of the dwg names is not always going to be the same.
    The old path and the new path will always be the same location. What would be the easiest way to do this?
    Thank you very much. I looked up some of the other routines but none of them seem to be making this process any faster. Any advice is appreciated.
    2009-11
    5,536
    Default Re: How to use a different xref and change path?
    Edit: Congrats on your first post, and welcome to the forums!
    Have you tried using Reference Manager..?
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,463
    How will the routine know the new name of the xref? Do you have a list already for which drawing contains the current xref and the proposed xref?
    Member tuomo.jarvinen's Avatar
    2015-09
    Jyväskylä, Finland
    38
    How about using Express - tool "redir", perhaps combined with "DoFile.lsp" ?
    Tuomo
    2010-02
    5
    Oh ahah I didn't realize that was my first post here.
    I figured similar to this:
    (command "-xref" "_a" * (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 8)*)
    Of course this does not work because I randomly added the * * to represent wildcards.
    (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 8)) is something I know would get the drawing name and remove the last 8 characters. So the drawing being 'Building-F03.dwg would now store the word Building. The only issue is not being able to add in the wildcard after. I was curious if it was possible to attach wildcard characters. Probably not eh?
    I'll give the redir a try!
    Earth
    9,754
    Quote Originally Posted by tslam View Post
    (command "-xref" "_a" * (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) *)
    (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) )
    Editing note: If you will edit your post (go to Advanced edit if necessary), scroll down to the Additional options, and you can disable smilies for a single post, which are showing up when you have an eight and and closed parenthesis like this , when it should look like this 8)
    (You can also do this at the time of a new post)
    R.K. McSwain | CAD Panacea |
    I could stop if I wanted to Revitaoist's Avatar
    2009-11
    380
    You could do this in minutes with the reference manager: -Start Menu - All Programs - Autodesk -Autocad 20XX - Reference Manager
    2002-01
    jUSt Here (a lot)
    8,463
    Quote Originally Posted by rhershberger View Post
    Really? I didn't think the Reference Manager allowed the filename change of the xref file itself. When did that get added?
    2000-01
    Seattle WA USA
    5,859
    Reference Manager does not handle changing the XRef filename. It only works to change the path of the XRef. (But Opie knows that.)
    R. Robert Bell
    Design Technology Manager
    Stantec
    2009-11
    5,536
    If this statement is true:
    Then the Reference Manager suggestion is your best solution.
    Regardless of the filenames being similar, the file path is *unique*. This makes changing the reference path necessary, and not renaming the reference itself.
    Hope this helps!
    Computer Specs:
  1. Change xref path type
    By jdcincy in forum AutoLISP
    Last Post: 2012-04-24, 04:50 PM
  2. rename and change xref path
    By krkeec763189 in forum Dot Net API
    Last Post: 2011-12-22, 01:29 PM
  3. Change xref name and path
    By krkeec763189 in forum AutoLISP
    Last Post: 2011-12-13, 06:56 AM
  4. Change Xref from Full Path to Relative Path
    By ccowgill in forum AutoLISP
    Last Post: 2009-05-27, 11:54 AM
  5. Replies: 1
    Last Post: 2007-05-05, 02:59 PM
