Thread: Hardware Revit UI and Hardware Acceleration - Maxi Vista
    2008-05
    443
    Default Hardware Revit UI and Hardware Acceleration - Maxi Vista
    Hi Everyone,
    I have a setup where I want to use my tablet PC as a second monitor. It does wonderfully with most software. The problem is that Maxi-Vista (the software to allow another PC as a second monitor over a network) doesn't work with DirectX or Open GL hardware acceleration.
    When it's on, I loose the ribbon in Revit. AutoCAD only looses the little save, open shortcut bar at the top (in classic, not sure about the ribbon).
    Anyone use a setup like this or know anything about the Revit UI and hardware acceleration options?
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Red face Re: Hardware Revit UI and Hardware Acceleration - Maxi Vista
    If it doesn't work with OpenGL or Direct3D, what DOES it work with?
    Sounds like you may be out of luck with RAC 2011 Direct 3D.
    cheers
    PS you might also see this:
    http://forums.augi.com/showthread.php?t=91418
    AUGI Addict iru69's Avatar
    2004-10
    usa
    1,591
    Default Re: Hardware Revit UI and Hardware Acceleration - Maxi Vista
    Quote Originally Posted by cliff collins View Post
    It's not that it doesn't work with anything, it doesn't work with hardware acceleration, i.e. it's not supported on the graphics card.
    Turning on HWA in Revit attempts use of the graphics card, which if not supported results in badness.
    Quote Originally Posted by 3dway View Post
    Just to be clear, if you turn off HWA in Revit, everything works fine?
    Someone on a blog mentioned that they're planning on releasing a new version with DX hardware support in the near future. I have no idea whether there's truth to that or how well it will work.
  1. hardware acceleration
    By alan613305 in forum AUGIuk
    Last Post: 2014-03-29, 12:57 PM
  2. Revit 2012 hardware [de]acceleration
    By Wes Macaulay in forum Revit - Hardware & Operating Systems
    Last Post: 2012-01-27, 05:38 PM
  3. OpenGL Hardware Acceleration
    By jbdesign in forum Revit - Hardware & Operating Systems
    Last Post: 2008-09-16, 10:41 PM
  4. Hardware Acceleration - Back on for 7???
    By christo4robin in forum Revit Architecture - General
    Last Post: 2004-10-27, 10:38 PM
  5. Hardware Acceleration?
    By MMccomb in forum AMEP General
    Last Post: 2004-07-30, 04:03 PM
