We just realized that all of our area schedules round similar to excel, where there is a discrepancy of 1 or 2 sf between the "Grand Total" and the actual total of the individual line items in the schedule. While this may be inconsequential, we:
1. Dont want to look like idiots in front of the client
2. Want to have accurate numbers for costing/pricing sets that will go to banks etc.
I wrote this workaround for my office to use. It's a bit **simple** so that everyone can understand it, but here it is. The instructions were meant to be applied to all of the area schedules and room schedule in each project, where "Area" is a field already included in the schedule. The process ends up hiding this field and creating a new field that is based on an integer.
1. Edit Schedule and go to View Properties
2. Click on Fields
3. Click on Calculated Value and create a field for your schedule
• Name: DISPLAY AREA
• Discipline: Common
• Type: Integer
• Formula: Area/1sf (this formula can be more complicated if there are other factors)
4. Click on the Formatting Tab within the Schedule Properties dialog box.
5. Click on Area
• UNCHECK "Calculate Totals"
• CHECK "Hidden Field"
6. Click on DISPLAY AREA
• Heading: AREA (SF)
• Alignment: Right
• CHECK "Calculate Totals"
• UNCHECK "Hidden Field"
7. Click ok
8. If you have already done the layout for your project info sheet, you will probably have to adjust the extents of the schedule for graphic reasons.
Hope this helps!
