I linked the arch revit file to my central file. But when I close and open it again, it is not appearing. I look on the 'Manage Links' tab and it says that it is loaded, so I'm not sure why it isn't appearing?
did you set up worksets? Is the link on a workset that is not turned on. Is the link turned off in the vg override area. I would also see if the elevations are set right. You could be defaulst 0ft. and the project could be 1000ft. These would be good things to look into for starters.
