Thread: Viewport Title Location In reference to viewport
    2006-03
    9
    Default Viewport Title Location In reference to viewport
    Is there a way to change the viewport title lock location in the family? Currently our viewport titles show up a certain distance from the left edge of the viewport and we need to change that standard to align with the right edge of the viewport without having to adjust it each time we drag a new viewport onto a sheet. Attached is an image of what I am talking about. thanks for any help.
    Example 1b is how it currently defaults
    Example 2b is how I would like it to default. (generally)
    -sun
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Viewport Title Location In reference to viewport
    You unfortunately cannot do that. You will need to manually move every title.
    2007-05
    SF CA USA
    314
    Does anyone with API experience know if this default offset placement can be adjusted? I'd love to have the ability to define the default, as well....
    2006-08
    636
    i did some API searching on viewport subject, API help file, API samples, API Lookup tool, etc., seems viewport not fully accessible yet, only have some builtin enumerated types as below, hope i'm wrong?
    VIEWPORT_SHEET_NAME
    VIEWPORT_SHEET_NUMBER
    VIEWPORT_STRETCH_FACTOR
    VIEWPORT_SCALE
    VIEWPORT_VIEW_NAME
    VIEWPORT_DETAIL_NUMBER
    VIEWPORT_CLIPPING
    VIEWPORT_ATTR_ORIENTATION_ON_SHEET
    VIEWPORT_ATTR_SHOW_BOX
    VIEWPORT_ATTR_SHOW_EXTENSION_LINE
    VIEWPORT_ATTR_SHOW_LABEL
    VIEWPORT_ATTR_LABEL_TAG
  1. Replies: 2
    Last Post: 2017-08-09, 01:04 PM
  2. Viewport Title Default
    By Jrobker in forum Revit MEP - General
    Last Post: 2010-10-27, 11:45 PM
  3. Viewport title
    By amindez9667 in forum Revit Architecture - General
    Last Post: 2010-02-08, 08:11 PM
  4. How do you find the viewport location on a sheet?
    By jvedio in forum Revit - API
    Last Post: 2008-04-08, 06:20 PM
  5. Rotation of Viewport & Viewport Title
    By iankids in forum Revit Architecture - General
    Last Post: 2007-12-19, 01:24 AM
