Thread: Inventor suite 2010 Network License via VPN
    2008-01
    4
    Default Inventor suite 2010 Network License via VPN
    I have a 3 license networked installation of Inventor Suite 2010 (Inventor & AutoCad Mechanical) at work. Only the license manager is installed on the server (Microsoft Server 2003). The Suite's are installed on individual PCs (all XP Pro, 32 bit).
    I want to install the Suite on my home PC (Windows 7, 64 bit) and access the license off the server at work via VPN. I have a fast cable internet connection. (Yes, I'm aware that I can "borrow" the license, but that process is just plain silly and annoying.) I want to set it up once and have it work all the time. If I'm not there at work using the license, then there is a license available for me to use at home.
    Is there any reason this will not work?
    Any first hand experience - advice - insight appreciated.
    2008-01
    4
    Default Re: Inventor suite 2010 Network License via VPN
    Just a follow-up, since apparently no one seems to have any firsthand info on this. I have it all setup as described above and it works perfectly.
  1. Revit 2010 Network License Manager
    By jcoe in forum Revit Architecture - General
    Last Post: 2010-04-27, 11:37 PM
  2. Network License Activation Utility for ACAD 2010
    By jguest82179 in forum CAD Management - General
    Last Post: 2010-04-16, 07:07 AM
  3. Вопросы по Autodesk Inventor Tooling Suite 2010
    By Rinat in forum Русский - Inventor
    Last Post: 2010-03-27, 09:55 PM
  4. Inventor 2010 License Borrowing
    By mark.philipp in forum Inventor - General
    Last Post: 2009-12-09, 04:54 PM
  5. Raster Design 2010 network license
    By clbreinholt in forum Raster Design - General
    Last Post: 2009-06-05, 02:29 PM
