Results 1 to 9 of 9
Thread: Curved raftes in vertical plane
    2008-07
    Brisbane (Ex. Swedish)
    349
    Default Curved raftes in vertical plane
    I have a curved roof which has a slight ellipse curve. Are there any way you can attach rafters to a roof or do I have to create a new beam family where I can change the curve of the rafters in vertical plane?
    J
    2008-07
    349
    Default Re: Curved raftes in vertical plane
    I found this thread but this means I have to create a ref plane for every rafter?
    http://forums.augi.com/showthread.ph...46#post1099679
    J
    2008-11
    Australia
    754
    You can create a curved rafter...
    Go to a section and draw a model line using the pick line tool to pick the curved face.
    Now create a beam and use the pick line tool again to place your beam and pick your model line. Revit will complain and tell you to pick a view perpendicular or plan view. It's been ages since I did this sorry, so I'm a bit sketchy on the method right now.
    You can use the model line as a pick line for the beam. You will need to relocate the beam once placed (in plan)
    I did a post a while back on purlins on the curved roof. I will attempt to find that for you
    http://forums.augi.com/showthread.ph...ht=curved+roof
    2008-07
    349
    I will give that a go - I wish though you actually could host a framing family to a roof
    J
    100 Club BecFra's Avatar
    2007-03
    Rock Island, IL
    114
    If it asks you to set it to a vertical plane, draw a "dummy" grid line, create an elevation view that is attached to the grid and then draw the beam in there. then delete the grid line. If all the curved beams are the same curve, you can group just the one beam and copy them where you need them. that way when you change one beam all the others change too.
    Becca Frangipane
    Structural Technician
    KJWW Engineering Consultants
    2008-11
    Australia
    754
    True, the grouping is what I did, just build one fully detailed rafter (I included all plates, bolts, and haunches in my group) and then copied that about. Takes a bit of stuffing around though, and make sure you copy any reference planes that you put in for cutting geometry into your group. Some times you have to take an item out that isnt working, then copy around your groups, then add that item in so it updates to all of your groups. I found this a bit fiddly, but at least I didnt have to model it multiple times so all up I think it saved a bit of time.
    2007-01
    226
    a round about way would use a flat truss, this would allow you to attach to roof.
    This would take shape of roof, Then delete the truss webs and bottom chord.
    2008-11
    Australia
    754
    Except this will schedule as a truss schedule and not structural framing...making your life harder further down the track that way
    2007-01
    226
    In Revit 2011 you can use the remove truss family function, then delete webs and bottom chords, the old top chord will schedule as a beam. I guess what we all would like to see in the new release is way to host beams and beam systems to a complex roof shape or to face of mass. It apears that the workflow for Revit is to start with mass, then add roof to face of mass, then start adding framing members, you can extend up and attach tops of column to this complex roof shape and attach trusses to roof shape.
  1. Vertical Curved Pipe
    Last Post: 2012-10-23, 03:24 PM
  2. rotate/Slope a wall in vertical plane
    By Art Vandelay in forum Revit Architecture - General
    Last Post: 2008-12-23, 03:34 PM
  3. curved beams in vertical plane
    By tripon.ciprian in forum Revit Structure - General
    Last Post: 2007-11-19, 12:21 AM
  4. vertical line against ref plane
    By iffans in forum Revit Architecture - General
    Last Post: 2005-06-20, 07:27 AM
  5. Mask difference on vertical plane vs. horizontal plane.
    By SkiSouth in forum Revit - Rendering
    Last Post: 2004-04-24, 01:08 PM
