Thread: Sanitary Plumbing Lines not staying connected
    2008-03
    Columbia/Jefferson City, MO
    224
    Angry Sanitary Plumbing Lines not staying connected
    Greetings All:
    I have a problem with the schematic sanitary pluming lines not staying where I put them when it comes to the fittings I have placed. In particular I have been using WYEs for my fitting connections and I will place them and it looks good. I will usually have to choose a resolution to the connecting plumbing line not being at the same elevation as the existing plumbing object, but after I choose an option it looks the way I want it. I then close the drawing and open it back up and either the fittings have shifted over a little or the plumbing lines have shifted over and I can't understand why. Has anyone had this trouble before? I am new to MEP we are using 2010. Thanks for reading. I would appriciate any help you all could provide.
    Mike Tuter
    2010-02
    6
    Default Re: Sanitary Plumbing Lines not staying connected
    i had that issue in ACAD MEP 2011 (and a lot of it i think was related to opening files that were started in 2010, but i cannot confirm)
    installing the latest appears to have solved that issue, but this was for 2011. i actually never saw the problem in 2010 version (which i used for a year) until i started working in 2011.
    now im having an issue with the "plus" (+) symbols on the schematic[plumbing] fittings... they want to go in the opposite direction of where they should. (its hard to explain)
    for now,
    i would just download all of the latest udates for your version and see if that helps any.
  1. 2016: Weird lines appear connected to surface...
    By GerroffMe in forum AutoCAD Civil 3D - General
    Last Post: 2015-07-11, 07:22 PM
  2. Replies: 1
    Last Post: 2013-10-26, 09:18 PM
  3. Plumbing lines not breaking at overlap in xref
    By zer0thre3 in forum AMEP General
    Last Post: 2009-09-15, 08:20 PM
  4. Plumbing Lines and Fittings
    By bbambu in forum AMEP Wish List
    Last Post: 2007-06-21, 06:09 PM
  5. Plumbing Lines
    By bbambu in forum AMEP General
    Last Post: 2006-11-16, 03:22 PM
