Thread: ActiveX Server returned an error: Element not found;
    2015-11
    38
    Default ActiveX Server returned an error: Element not found;
    Hello, im hoping someone has a fix for me......
    A Laptop using WinXP SP3 and AutoCAD2011, after a recent crash shows me the error; "ActiveX Server returned an error: Element not found." when trying to use the 'vlax-invoke-method' function to execute the 'GetXData' method.
    There is nothing wrong with the lisp code as it works fine on 15 other CAD stations all installed with AutoCAD2011.
    Re - installation / repair of AutoCAD doesnt seem to work neither does uninstall / reinstalling the VBA enabler.
    A version of DWG viewer had been installed/uninstalled which caused a problem with AutoCAD & .NET and was fixed by our IT department somehow.
    Any ideas of a fix....
    Many thanks.
    2015-11
    38
    Default Re: ActiveX Server returned an error: Element not found;
    This particular problem has occured again. Although the error is different it still points to some problem with VBA/ActiveX - again after installing DWG viewer AutoCAD 2011 & 2012 will error for a VBA macro that works on every other machine with 'member not found' for this line of code;
    If Object.ObjectName = "AcDbRotatedDimension" Then.....
    ... any help would be appreciated.
    The only solution found so far is a complete system reinstall!!
    Many thanks.
  1. Error loading Navis ActiveX Plugin on IE
    By potapczuk542577 in forum NavisWorks - General
    Last Post: 2012-06-19, 09:02 PM
  2. Run-time error '429' (ActiveX component can't create object)
    By Pwned555402908 in forum VBA/COM Interop
    Last Post: 2011-12-08, 10:05 PM
  3. ActiveX error
    By d_m_hopper in forum AutoLISP
    Last Post: 2010-08-05, 04:26 PM
  4. ActiveX Error Help....?
    By CADdancer in forum AutoLISP
    Last Post: 2010-04-05, 04:17 PM
  5. Replies: 4
    Last Post: 2004-07-24, 04:18 AM
