Thread: Inventor 2011 check out
    Member bub4's Avatar
    2002-12
    The Spud State
    26
    Default Inventor 2011 check out
    I am having difficulty with checking files out of vault in Inventor 2011. In prior versions I would check out the .idw file and it would check out all associated .iam, .ipt etc. files. I have found that I have to individually place a check next to the files I want. I do toggle to include children in the check out process.
    Any ideas?
    2009-01
    Calgary, Alberta, Canada
    22
    Default Re: Inventor 2011 check out
    It sounds like the default behaviour in Vault Explorer 2011. Instead of using Vault Explorer, if you go to inventor, open from vault, and use the vault tab of your browser bar, it will allow you to check out all files like you are asking.
    2002-12
    The Spud State
    26
    This is the process I use to check out files. I was thinking it's a setting I don't have set correctly but have been unable to find it.
    Manufacturing Moderator jonathan.landeros's Avatar
    2005-03
    Los Angeles County, Ca.
    440
    I don't know of a way to make Vault check out all all the time, but if you're opening from Vault (in Inventor), you can choose check out all from the open menu.
    If you're checking out from Vault Explorer, right clicking gives you the option to 'Check All' at that menu.
    Hope this helps!
    Jonathan Landeros
    KETIV Technologies
    Orange County, California.
    I've got a blog: www.inventor-tales.blogspot.com
    “We have now left Reason and Sanity Junction.Next stop, Looneyville.” -Bob the Skull in the Dresden Files
  1. Check Air and Liquid Flow In Inventor
    Last Post: 2012-08-22, 04:04 AM
  2. Autocad 2011 Check-In DWF file genreration
    By Mike Y in forum Vault - General
    Last Post: 2010-11-02, 08:22 PM
  3. Inventor/Vault Check-In
    Last Post: 2010-09-16, 02:10 PM
  4. Spell Check for inventor 08
    By sjwinn in forum Inventor - General
    Last Post: 2008-02-03, 04:46 PM
  5. Check holes in inventor
    By jfurtado in forum VBA/COM Interop
    Last Post: 2006-03-08, 03:42 PM
