I have a mystery. I am upgrading our content from ACA2008 to ACA2011. I have an annotative grid bubble tag that works fine in ACA2008, but after upgrading it to 2011, it inserts itself at a scale of .09375 instead of 1.
I am trying to use the AECCREATECONTENT wizard to get the block setup for use in a tool palette via design center. If I use the Custom Command (preferred) method, the grid tag is always inserted at a scale of .09375. If I use the wizard and change the Content type to "Block" it inserts and scales fine albiet with the rude block insert dialog intervening.
Does anyone know what might be causing the tag to be scaled down to something other than 1?
