Hi All,
Wishes of New Year in advance.
Please find attached drawing. In this drawing if I try to copy blocks the copied blocks will not be visible till I regenerate the drawing. (RegenAuto is set to "on" & Regenmode is set to "1").
Add on to this problem I am not able select the copied block. In case if I have to erase the block I have to zoom in to that block and select as last entity. I am using Mechanical Desktop 2004-DX
Please suggest me in case any variable I have to set.
Thanks in advance
Raj
