Thread: Create a polyline
    2004-08
    Beaverton, Or.
    132
    Default Create a polyline
    How do you create a polyline with .net starting with a 3d point (user input)? I have found lots of examples of creating plines with hard coded points, but none that start with user input.
    Any help would be great.
    2009-11
    5,733
    Default Re: Create a polyline
    Quote Originally Posted by clintonc View Post
    Store a series of points to variables (pt1, pt2, pt3, etc.) then build your polyline accordingly.
    Computer Specs:
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Here is very easy example not so elegance though
    Imports System
    Imports Autodesk.AutoCAD.Runtime
    Imports Autodesk.AutoCAD.Geometry
    Imports Autodesk.AutoCAD.EditorInput
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.GraphicsInterface
    Imports Autodesk.AutoCAD.ApplicationServices.Application
    Imports AcadRT = Autodesk.AutoCAD.Runtime
    Imports AcadED = Autodesk.AutoCAD.EditorInput
    Imports AcadDB = Autodesk.AutoCAD.DatabaseServices
    Imports AcadApp = Autodesk.AutoCAD.ApplicationServices.Application
    Public Class PlineUtils
        <CommandMethod("TP")> _
        Public Sub InteractPline()
            Dim adoc As Autodesk.AutoCAD.ApplicationServices.Document = AcadApp.DocumentManager.MdiActiveDocument
            Dim db As Database = adoc.Database
            Dim ed As Editor = adoc.Editor
            Dim vec As Vector3d = New Vector3d(0, 0, 1).TransformBy(ed.CurrentUserCoordinateSystem)
            Dim plane As Plane = New Plane(db.Ucsorg, vec)
            Dim res1 As PromptPointResult = ed.GetPoint(ControlChars.CrLf & "Select first point: ")
            Dim bp As Point3d = New Point3d(res1.Value.X, res1.Value.Y, res1.Value.Z)
            Dim ar As ArrayList = New ArrayList
            ar.Add(bp.X)
            ar.Add(bp.Y)
            Dim res2 As PromptPointResult
            Dim n As Integer = 0
            Do
                Dim opt As PromptPointOptions = New PromptPointOptions(ControlChars.CrLf & "Select next point: ")
                opt.AppendKeywordsToMessage = True
                opt.UseBasePoint = True
                opt.BasePoint = bp
                opt.AllowArbitraryInput = True
                opt.SetMessageAndKeywords(ControlChars.CrLf & "Select next point: " & "Or Yes to Exit [Y/N]", "Yes No")
                res2 = ed.GetPoint(opt)
                bp = New Point3d(res2.Value.X, res2.Value.Y, res2.Value.Z)
                ar.Add(bp.X)
                ar.Add(bp.Y)
                n += 1
            Loop Until res2.Status = PromptStatus.Keyword
            Dim Pline As Polyline = New Polyline(n)
            For i As Integer = 0 To ar.Count - 1 Step 2
                Pline.AddVertexAt(0, New Point2d(ar(i), ar(i + 1)), 0.0, 0.0, 0.0)
            Next i
            Pline.Normal = vec
            Pline.RemoveVertexAt(0)
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                btr.AppendEntity(Pline)
                tr.AddNewlyCreatedDBObject(Pline, True)
                tr.Commit()
            End Using
        End Sub
    Guess, you might want to search for Jig entity examples in AU docs
    as well
    ~'J'~
    2002-10
    154
    AutoDesk has some examples of this and much more...
    http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html?url=WS1a9193826455f5ff2566ffd511ff6f8c7ca-4217.htm,topicNumber=d0e10700
  1. create alignment from 3d polyline
    By wardorichie in forum AutoCAD Civil 3D - General
    Last Post: 2017-09-29, 09:06 AM
  2. Create Polyline Offset
    By khanhtruongcivil399200 in forum AutoLISP
    Last Post: 2014-10-16, 11:36 AM
  3. 2011: Create a polyline Section from surface?
    By scowsert in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-09-02, 11:03 AM
  4. help corrirdor -> create subassembly from polyline
    By ociosidad in forum AutoCAD Civil 3D - Corridors
    Last Post: 2009-06-15, 03:25 PM
  5. Create 3d Polyline Step
    By td729 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2008-04-26, 01:47 PM
