Results 1 to 9 of 9
Thread: Open PDF file from ACAD
    2003-06
    North Dallas
    168
    Default Open PDF file from ACAD
    Is there a command that will allow me to open up a PDF file from autocad similar to the "EXPLORER" or "NOTEPAD" command? I notice when using these commands that a DOS(?) window quickly pops up and disappears.
    2009-11
    5,719
    Default Re: Open PDF file from ACAD
    Here's what I use to open our CTB documents. This detects which version of AutoCAD is being used, then opens the appropriate document, as it relates to that version (each has a different standard):
    (defun c:CTB  ()
      (vl-load-com)
      (cond (*vrsn*)
            ((setq *vrsn* (vlax-product-key))))
      (cond
        ((vl-string-search "R16.2" *vrsn*)                                  ; 2006
         (startapp
           "C:\\Program Files\\Adobe\\Reader 8.0\\Reader\\AcroRd32.exe"
           "FilePath\\FileName.pdf"))
        ((vl-string-search "R17.2" *vrsn*)                                  ; 2009
         (startapp
        (T (alert "This Version of AutoCAD Not Supported. ")))
      (princ))
    Hope this helps!
    Computer Specs:
    2003-06
    North Dallas
    168
    using your code I can get Adobe to open but get an error stating the file cannot be found. I've copied the file in the same folder as the adobe executable. Anything I'm doing wrong here?
    (defun c:NEC ()
      (startapp "C:\\Program Files (x86)\\Adobe\\Acrobat 8.0\\Acrobat\\Acrobat.exe"
                "C:\\Program Files (x86)\\Adobe\\Acrobat 8.0\\Acrobat\\NECH08.pdf")
    (princ)
    );eof
    2003-06
    North Dallas
    168
    I moved the file to the C drive and it worked...Can't imagine what the problem is. Thanks for your help.
    2003-06
    North Dallas
    168
    Rookie Lisper mistake. I forgot to enclose the file name in quotes since it has spaces in it.
    (defun c:NEC ()
                \""C:\\Program Files (x86)\\Adobe\\Acrobat 8.0\\Acrobat\\NECH08.pdf\"")
    (princ)
    );eof
    0,0,0 The Origin
    8,570
    Just in case anyone cares -
    you can open any document with its registered application from within acad.
    Do File\Open and type *.* or *.doc or *.pdf in the filename box. Navigate to the file, right-click and select Open.
    Earth
    9,804
    Quote Originally Posted by mvsawyer View Post
    If you want to open the PDF using the registered application, regardless of what might be installed, then take a look at this: http://cadpanacea.com/node/22. This way you avoid trying to guess what program might be installed, and where it's installed, etc.
    If you insist on specifically opening Adobe as shown above, then you might want to consider using the %programfiles% variable so don't have to guess (or test for) \Program Files vs. \Program Files (x86)
    R.K. McSwain | CAD Panacea |
    2003-06
    North Dallas
    168
    I knew there was a way to use the shell like explorer or notpad does. Great link rkmcswain. Thanks alot!
    2009-11
    5,719
    The code posted above was explicit, as all CAD users had that specific version installed. My region's offices are in transition right now to our new systems (servers, applications, directory structures, etc.) and this will come in handy as we move ahead.
    Thanks for sharing RK, cheers!
    Computer Specs:
  1. Replies: 2
    Last Post: 2014-10-17, 04:57 PM
  2. 2005: Object Enabler to open file in Acad 2005?
    By Marie789 in forum AutoCAD General
    Last Post: 2014-03-27, 05:14 PM
  3. Replies: 3
    Last Post: 2012-06-17, 09:42 PM
  4. From acad (only acad) File\Open I am unable to access my C: drive
    By jaberwok in forum CAD Management - General
    Last Post: 2005-11-13, 07:53 PM
  5. open file dialog box slow to open
    By klanier in forum AutoCAD General
    Last Post: 2004-09-09, 02:51 PM
