Thread: Moving a complete project up/down
    2009-01
    43
    Default Moving a complete project up/down
    I have a project with construction drawings almost fully documented without knowing the datum for the levels of the project. I need to raise the building / surface / everything to make it consistent with the now confirmed datum level. The result I need is nothing more than to change the numbers in the Level Heads in elevs, sects, details, etc. In simpler CAD programs, you would simply change the numbers in the level heads on the relevant drawings. But as we all know, Revit doesn't work like that. Grabbing the Levels and objects in a section/elevation will leave a horrible mess with all the detail lines/elements/insulation in the detail drawings. Sure, I can go through each elevation, section + detail, but in that case I might as well forget about being productive or profitable...
    Does anyone know of the correct or most effective way to achieve this otherwise simple change in levels?
    2004-01
    Columbus OH
    465
    Default Re: Moving a complete project up/down
    Thats a job for the Relocate Project tool. Its on the manage tab under Position.
    2004-05
    Auckland, New Zealand
    341
    Or just make the Level's shared, and tell it specifically what the Heights are
    2009-01
    43
    Thank you!
    Actually, it was a combination of both. I had to change the Elevation Base of the Level Type to Shared, then I used the Relocate Project tool in elevation. Without the "shared" elevation base, relocating the project evidently does effectively nothing.
    Obviously this is something I don't do often. Thanks again.
  1. Create template from complete project
    By jcarrillo.75185 in forum Revit Architecture - General
    Last Post: 2017-12-22, 01:17 AM
  2. Moving Project
    By snowocean in forum Revit Architecture - General
    Last Post: 2012-05-09, 08:33 PM
  3. 2012: Moving Project to New Project Base Point
    By WYSIWYG-BIM in forum Revit Architecture - General
    Last Post: 2011-08-22, 03:07 PM
  4. Provide me with complete project & timeliner
    By carty_girl in forum NavisWorks - General
    Last Post: 2009-02-26, 01:40 AM
