How is everybody detailing CMU wall reinforcing bars? Are folks modeling the bars or simply drawings the bars with detail lines in each section cut through a CMU wall? I have an 8" CMU wall with #4 bars @ 24" at the wall centerline. I can model a #4 bar in the wall and set the maximum spacing to 2'-0". However depending on where I cut another section through that wall, the rebar may not show up in the section. Therefore I end up having to draw a bar in the wall with detail lines.
Edit: The text in italics is incorrect. The modeled bars do show up in any section I cut through the CMU wall with #4 bars modeled at 2'-0" on center.
Also on the subject of CMU walls in section, our office prefers to show the CMU in greater detail than the standard crosshatch fill pattern. We show face shells and mortar joints. Right now we are accomplishing this by using a repeating detail of the CMU Section detail item in every section that cuts through a CMU wall. Anyone else showing CMU walls this way, or have a better way of showing the CMU in greater detail?
