Thread: VBA ENABLER Autocad Electric 2011 tools
    2008-02
    49
    Default VBA ENABLER Autocad Electric 2011 tools
    Hi to everybody I would like to put a question to this forum just to know how to fix a problem concerning the Vba Enabler tools for Autocad.
    I have reinstalled Autocad Electric 2011 x64 on windoes 7, and the Vba enabler tools, after a pc formatting.
    Before the pc's formatting I had a vba project perfectly working, but now seems that a simply command like Right$ doesn't works, the debug operation give me an error "cannot find the libray".
    Pls help me.
    2008-02
    49
    Exclamation Re: VBA ENABLER Autocad Electric 2011 tools
    No Idea about My issue ?
    Somebody knows if, in order to use VBA for Autocad, is needed some other tools ? example Visual studio ? or any others software ?.
    Thanks
    Turlock, CA
    6,379
    Default Re: VBA ENABLER Autocad Electric 2011 tools
    You probably didn't reinstall a program that you referenced previously. Go to Tools>References and look for the library that has "MISSING:" in front of it. If it is installed, then select the checkbox.
    C:> ED WORKING....
  1. 2016: AutoCad Electric will not start
    By Rich_R in forum AutoCAD Electrical - General
    Last Post: 2015-09-01, 03:10 PM
  2. Autocad Architecture 2011 Electric Schedule Template
    By chosah691975 in forum ACA General
    Last Post: 2015-03-31, 07:14 PM
  3. Prosteel Object Enabler for AMEP 2011
    By rommel_1811 in forum Software
    Last Post: 2010-10-18, 03:44 PM
  4. Researching Design Tools - Electric Utility Controls
    By jweaver in forum AutoCAD Electrical - General
    Last Post: 2008-05-28, 05:00 PM
  5. AutoCAD Enabler
    By Red Devil in forum AutoCAD General
    Last Post: 2007-06-27, 01:44 PM
