Thread: Current Tablestyle
    2009-02
    London, England
    21
    Smile Current Tablestyle
    Hi
    Hope someone can help which I believe to be a simple task .
    Using VBA in Autocad i need to do the following:
    1.Give value for the active tablestyle
    2.Change the active tablestyle to a string
    3. Return to previous active tablestyle.
    From what I found so far the tablestyles are hidden in dictionaries but I can't figure the above out !?
    Cheers
    Steve.
    2009-02
    London, England
    21
    Default Re: Current Tablestyle
    Have found it, in case anyone else needs it
    Dim CurrentTableStyle As String
    CurrentTable = thisdrawing.getvariable("ctablestyle")
    Dim NewTableName as string
    NewTableName = "NEWTABLE"
    ThisDrawing.SetVariable ("ctablestyle"), NewTableName
    ThisDrawing.SetVariable ("ctablestyle"), CurrentTable
  1. How to create a new TableStyle ?
    By viz_ken1030 in forum AutoLISP
    Last Post: 2011-11-23, 01:35 PM
  2. how do I change current TableStyle?
    By allen.hart in forum Dot Net API
    Last Post: 2010-02-16, 03:23 PM
  3. Dictionary for TableStyle not creating.
    By Dave F. in forum VBA/COM Interop
    Last Post: 2009-05-25, 11:39 PM
  4. TableStyle command in lisp
    By am4soft in forum AutoLISP
    Last Post: 2009-01-11, 02:28 PM
  5. Tablestyle command is unresponsive
    By dmorrell in forum AutoCAD Tables
    Last Post: 2006-08-18, 01:23 PM
