Thread: Sheet set / Sheet custom properties data validation
    2015-11
    11
    Exclamation Sheet set / Sheet custom properties data validation
    Hi,
    I need to apply some kind of “data validation” on the custom properties entries to maintain some consistency throughout the whole sheet set regardless of which team member had filled it in, and also to eliminate spelling mistakes as possible.
    To achieve this, I need to be able to do the following:
    1-Get some of the sheet set custom properties to be filled using a preset drop down list (i.e. “Project Status” > “DRAFT”, “PRELIMINARY”,…etc).
    2-Some of the long drop down lists will need to be referenced from an external data file (i.e. an XLS file containing all the localities names).
    3-Control the date’s entries to be in one specific format only (i.e. dd/mm/yy not dd-mm-yy).
    Regards
    Cairo - no, not Illinois
    4,912
    Default Re: Sheet set / Sheet custom properties data validation
    simplest approach would be to look at jtbworld.com for his sheet set editing tools. while I don't think that will give you external validation from a spreadsheet, it will give you a table format for editing/comparing multiple sheets in the set concurrently.
  1. Custom sheet properties
    By Bryan Thatcher in forum ACA General
    Last Post: 2009-03-13, 06:56 PM
  2. Replies: 5
    Last Post: 2009-02-23, 09:12 PM
  3. Sheet set custom properties
    By feargt in forum VBA/COM Interop
    Last Post: 2009-02-16, 11:34 PM
  4. Sheet Manage Custom Properties
    Last Post: 2007-09-27, 06:06 PM
  5. Sheet Set Custom Properties
    By kschultz in forum AutoCAD Sheet Set Manager
    Last Post: 2005-09-02, 05:48 PM
