Thread: Are they the same?
    2003-11
    4
    Default Are they the same?
    I currently have the AutoDesk ADA 2008 and wonder if the 3D VIZ will work as 3Dz MAX?
    I will be using the program with a 3D gaming program and the min. requirement is saying use MAX. I will need to upgrade to the 2011 ADA if they won't interchange.
    I hope this is clear enough but I wanted to keep it pretty general.
    Thanks
    2003-11
    4
    Question Re: Are they the same?
    Quote Originally Posted by dcassity140017 View Post
    Thanks
    Anyone venture a guess??????
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: Are they the same?
    3ds VIZ was discontinued several years ago, even then you could not add something to VIZ to make it 3ds MAX. You can open viz files with 3ds max, but not the other way around. You would in essence need to buy a standalone version of 3ds max / 3ds max design.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
