Thread: Can I set Drawing Orientation in VB?
    2007-12
    4
    Default Can I set Drawing Orientation in VB?
    I am using AutoCad 2004.
    I need to set the Drawing Orientation programatically from inside VB.
    I am using the 'ThisDrawing' object to do most of the other work I need.
    But when I check its structure in VB's Watch Window, I can't find an Orientation property.
    I also used the on-line AutoCad help, and I can't find a reference there either.
    For a number of reasons, I cannot use a plot config file to set this.
    Thanks, gvp
    5,756
    Default Re: Can I set Drawing Orientation in VB?
    First, welcome to the forums.
    Check out the PlotConfiguration.PlotRotation property.
    2007-12
    4
    Thanks. The plot rotation settings did indeed set the orientation correctly.
    For my application, I needed "upside down Landscape", so setting PlotRotation = ac180degrees worked nicely.
  1. 2012: UCS Orientation
    By cjshaw in forum AutoCAD LT - General
    Last Post: 2013-06-19, 03:00 PM
  2. 2011: Tag Orientation
    By huntbh in forum Revit Structure - General
    Last Post: 2012-05-04, 11:58 PM
  3. UCS Orientation
    By dan.spinella in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-04-23, 02:51 PM
  4. dim orientation?
    By smdin79 in forum AutoCAD LT - General
    Last Post: 2005-04-19, 03:34 PM
