Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: How to Detect Visual Style
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default How to Detect Visual Style
    For example, if the visual style is wireframe in the current drawing.
    How to detect it by autolisp?
    Your helps are much appreciated.
    2006-04
    1,160
    Default Re: How to Detect Visual Style
    The reason which I rose was that I cannot see any system variables to do the job.
    I'd like to know if there is any solution for this.
    2004-08
    Iron Station, NC
    3,197
    I have not been able to find any system variables either. Is there a way to list environmental variables? perhaps it is one of those (similar to tool palette paths)
    2006-04
    1,160
    Quote Originally Posted by ccowgill View Post
    I did a search but could not find the EV list.
    Thanks.
    Perhaps we need a new system variable next version.
    2010-10
    535
    Same problem i had when i was looking for the last distance used in offset command
    anyhoo...
    by extracting several system variables for every Standard Visual Style (out of the box)
    I'll select "Conceptual" as the current visual style
    and i'll run this
    (foreach var  '(
    		"VSEDGECOLOR"
    		 "VSEDGES"	       "VSEDGESMOOTH"
    		 "VSFACESTYLE"	       "VSMATERIALMODE"
    		 "VSOBSCUREDEDGES"     "VSOBSCUREDLTYPE"
    		 "VSSILHEDGES"	       "VSSILHWIDTH")
      (print var)
      (print (getvar var))(princ))
    you will note the difference between each Vstyle and i guess you can make a matrix which condtion
    is unique to the current visual style and from there derive a basis
    give it a try.. i'm not sure though. its a shot in the dark
    2001-07
    318
    To find a variable you could try
    (at the acad prompt)
    lsp
    if you already haven't try it..
    2006-04
    1,160
    Thanks to pbejse & clovis.
    But what I want is to find something can return a value of the visual style, just is similar to osmode.
    So preferring a (getvar "XXX") could do the job.
    2015-12
    2,095
    Quote Originally Posted by BoKirra View Post
    Define "value" in this context? Unlike osnaps with their individual on/off settings visual styles have a boatload of settings with their own accepted values.
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Perhaps, like this
    ((lambda ()
       (vl-load-com)
    (vl-catch-all-error-message
      (vl-catch-all-apply '(lambda()
       (setq vp (vla-get-activeviewport
        (vla-get-activedocument (vlax-get-acad-object)))
      vp (vlax-vla-object->ename vp)
      elist (entget vp)
      vs (cdr (assoc 348 elist))
      vlist (entget vs)
      vstyle (cdr (assoc 2 vlist)))
       (alert vstyle))))))
    2006-04
    1,160
    Quote Originally Posted by fixo View Post
    Perhaps, like this
    ((lambda ()
       (vl-load-com)
      elist (entget vp)
      vlist (entget vs)
       (alert vstyle))))))
    Thanks for your help.
    I tried but it returns the message:
    #<SUBR @000000002f428200 -lambda->
  1. 2014: Visual Style As Seen vs How it prints
    By boyerd492098 in forum AutoCAD 3D (2007 and above)
    Last Post: 2015-05-13, 10:59 PM
  2. 2011: Visual Style Overrides Plot Style
    By CADMariner in forum AMEP General
    Last Post: 2011-06-16, 02:03 PM
  3. Visual Style Dilema
    By rod.abbott in forum AutoCAD Customization
    Last Post: 2009-09-01, 09:39 AM
  4. Visual Style issue
    By Gary.182361 in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-08-29, 06:44 PM
  5. 3D Visual Style .DWG Corruption
    By fhoffnar in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-08-11, 01:23 PM
