I looked for a forum on this but could not find a post. I have Revit files we take into Max to render on a regular basis. Rendering on the machine that exports the fbx file works fine, what seems to be happening is all Revit materials are going out to c/temp. So when this file is sent to backburner to be rendered on the farm it is producing an "Invalid Image File Header" issue. If you open max and look at the materials in slate editor and open one of the images it says that same error where you should see the image. Repath it to the one in the max folder and its fine. What this tells me is that we cant render revit in max to the farm because the materials are being dumped into c/temp. Used to have an fbm folder and that no longer exists. If you render to one machine everything looks great, however it takes forever and thus the purpose of sending it to the farm. Anyone have any good suggestions on how to fix this other than removing all materials and starting over once in max, or trying to remap all materials. both of which are very time consuming.
