jetisart
I've got some problems with Filled Regions, I think that the following example will describe it the best:
When I use several different Filled Regions ("Earth", "Sand", "Concrete", etc.) while detailing the section in the Section view, all works just fine. Then I insert this View into the Sheet and add some adnotations (still on the sheet). The adnotations that are positioned partially or fully over Filled Region (including their arrows) disappear UNDER (!!!) those Regions (partially or fully - respectively). I tried even to send the Filled Regions all the way "to back" - "behind" other objects, but that didn't help. And funny thing is, that while the parts (or whole) of the adnotations don't show on the screen, the still print correctly over the fills... until I use two or more Regions (one partially on the top of the other - overlaping). Then the adnotations not only don't show on the screen, they don't print either (or their "covered" parts...)
What puzzles me the most is, that while Regions are parts of a View (ACAD "model space"), the adnotations are on the Sheet ("paper space"), so why they should be affected?
Any ideas?
Puzzled Jerry.
