Thread: Station Offset Label Question
    2005-01
    Columbus, IN
    23
    Default Station Offset Label Question
    Is it possible to extend the leader line under the text portion of this type of label? We have a style that has stacked text with the Station over the Offset but the leader line is attached to the middle right of the text and I want it to extend under the text. Any help?
    2009-04
    Fort Wayne, IN
    151
    Default Re: Station Offset Label Question
    Here's how I handle it.
    In your style, layout tab, add a component for "Line". Have this component be anchored to your Feature.
    Add two components for text, one anchored above the line, and one anchored below the line. (My text is reference text that references the aligment to automatically update.)
    When you need to stretch the label, the leader should then be attached to your horizontal line. If you need to change the length of your horizontal line to fit your sheet better, you can click on the leader and add a vertex.
    Scott
  1. Autolisp program to label station and offset.
    By aaronic_abacus in forum AutoLISP
    Last Post: 2020-09-16, 01:36 AM
  2. 2011: label points at an offset from alignment showing stat, offset, and description
    By mw156 in forum AutoCAD Civil 3D - Survey
    Last Post: 2016-09-29, 06:10 PM
  3. Replies: 18
    Last Post: 2010-09-22, 09:21 PM
  4. Alignments - Label Station and Offset
    By todd.80290 in forum Land Desktop - General
    Last Post: 2009-12-10, 09:39 PM
  5. Label Station & Offset
    By td729 in forum AutoCAD Civil 3D - General
    Last Post: 2008-06-17, 04:55 PM
