Thread: Question about revision clouds and deltas
    2008-06
    Denver, CO
    179
    Default Question about revision clouds and deltas
    This is a question from someone that hasn't taken a project all the way through completion so I haven't used revision clouds or deltas yet, so I don't know exactly how they work in Revit.
    I'm glancing through a project right now that was done by another firm in Revit and I noticed an oddity. On each sheet the delta numbers are different. For instance, let's say they issued a Bulletin #63 on 06/21/2010. On one sheet, this bulletin is Delta 5, on another Delta 10, and on another Delta 3.
    I always assumed that a specific delta number referred to a specific issuance on a specific date. However, in this project, it seems that each sheet is delta numbered sequentially without reference to a project-wide issuance. (i.e. sheet A-100 has Delta 1,2,3.... sheet A1-101 has Delta 1,2,3,4,5,6... etc.)
    Is this common? Can Revit handle Deltas in both methods?
    2002-09
    Madison, WI
    5,688
    Default Re: Question about revision clouds and deltas
    Quote Originally Posted by Ryan Taube View Post
    It's way more common IMHO to revise each sheet sequentially and individually. On large projects where you may issue responses to say 100 RFI's and do say 40 CB's. The delta should be tied to how many times you revised or reissued the sheet. I don't think I've ever seen a revision block go 1,4,8,10. It would make me wonder what happened to the other revisions.
    Make sense?
    2009-05
    Pittsburgh, PA
    245
    Yes, Revit handles both methods...
    In the Sheet Issues/ Revisions dialog box you have the option to track your revisions Per Project or Per Sheet. Your example is Per Sheet.
  1. 2011: Params in revision deltas
    By revituser195 in forum Revit Architecture - Families
    Last Post: 2011-12-28, 10:34 PM
  2. Halftone option for showing revision clouds within revision manager.
    Last Post: 2011-12-02, 04:22 PM
  3. Revision Clouds line weight different per Revision
    By billy007nh in forum Revit Architecture - General
    Last Post: 2010-11-18, 05:55 PM
  4. Revision Clouds
    By Les Therrien in forum Revit Architecture - General
    Last Post: 2005-12-29, 04:19 PM
  5. Revision Clouds and Deltas
    By cstarr in forum Revit Architecture - General
    Last Post: 2005-08-23, 03:52 PM
