Results 1 to 10 of 12
Thread: Missing Xref Manager - AutoCAD 2010
    2007-05
    11
    Default Missing Xref Manager - AutoCAD 2010
    My Xref Manager is missing, and I can't find it anywhere. When I click on the Xref button toggle the command line indicates that the xref manager is opening and closing, but it doesn't appear on the screen. It's name doesn't appear on any of the docked palettes. I've tried using alternative workspaces, hoping that the location of a xref-manager might be reset in alternate workspaces, without success. I've even tried placing a secondary monitor around the screen to see if it is just out of view. No good.
    In the old days (can 2006 really count as old days?), when the Xref palette was a dialog box, I could use Alt+Space then Move to bring the window into view. No such luck today.
    I can use the old version (CLASSICXREF), which is OK as a work around, but I'd REALLY like to know what's going on and fix it. Any suggestions?
    Thanks!
    --Matt Ritzman
    2004-08
    Iron Station, NC
    3,197
    Default Re: Missing Xref Manager - AutoCAD 2010
    Quote Originally Posted by mritzman View Post
    Thanks!
    --Matt Ritzman
    Perhaps try opening the CUI editor, then with your current workspace selected in the left pane, click on the + next to Palettes in the right pane. Then select the External References palette, and make sure it is set to show, also set any other properties that are relevant. Perhaps that will allow it to appear.
    Christopher T. Cowgill, P.E.
    Autodesk Expert Elite
    AEC Collection Civil 3D 2020
    Windows 10
    2007-05
    11
    That did it! I've attached an image of where I went to make the adjustment, in case anybody else runs into the same issue.
    I suspected it was something like that, but I couldn't seem to find it in the help files or online.
    Thank you! Thank you! Thank you!
    2004-08
    Iron Station, NC
    3,197
    glad I could help.
    Windows 10
    2011-04
    Hi Guys,
    Can anyone please help with this same issue in CAD 2011?
    I am not very familiar with the CUI interface and now it also appears there are no palettes available for me to select from?
    Thanks in advance!
    2004-08
    Iron Station, NC
    3,197
    Quote Originally Posted by benhorton985760 View Post
    Hi Guys,
    Thanks in advance!
    the 2011 cui is almost identical to 2010, 2012 is as well. The instructions I gave above were using 2011 so they should work for you as well. Can you post a screen shot of your CUI dialog?
    Windows 10
    2013-08
    Quote Originally Posted by ccowgill View Post
    This worked perfectly... thank you so very much
    2011-10
    Pleasanton, CA
    12
    Cool Re: Missing Xref Manager - AutoCAD 2010
    Matt, thanx for posting the image! that was what we needed for our 2014 install! one additional tip, we had to select "floating" under the "allow docking" option, otherwise it stayed missing. (ps. hope you're doing well!)
    LG
    2012-05
    Marvelous - the screenshot you posted really helped..
    After trying 10 google search links on this topic. your's did it !!
    (note: I too only found it setting orientation to 'floating'. )
    Thanks again.
    2011-05
    20
    Thank you so much. This was driving me nuts. I appreciate it so much when people go out of their way to post solutions to problems they have faced and help others in the process. I always try to do the same myself.
  1. 2014: Missing xref manager 2014
    By MarkLyon in forum AutoCAD General
    Last Post: 2014-02-21, 01:52 PM
  2. AutoCAD 2010 missing second input
    By schrodingerscat in forum AutoCAD General
    Last Post: 2009-12-22, 06:00 PM
  3. Layer States Manager missing in AutoCAD 2004
    By matthew.209657 in forum AutoCAD General
    Last Post: 2009-02-24, 04:22 PM
  4. Missing XRef Manager
    By Logan in forum AutoCAD LT - General
    Last Post: 2008-02-21, 11:46 PM
  5. AutoCAD LT 2007 - Xref does not show in External Reference manager
    By tiffany.amorgan in forum AutoCAD LT - General
    Last Post: 2006-12-06, 02:51 PM
