Thread: Autodesk 2010 Slows Machine
    2011-01
    Default Autodesk 2010 Slows Machine
    After installing Autodesk 2010, our office computers seem to lag about 5 seconds when opening a Windows XP browser window. For instance, if you try to open "My Documents" the folder will lag (~5 sec) while trying to open. Explorer, Office suite, AutoCAD, etc... all open just fine, its just the browser windows.
    Does anyone know what causes this or how it can be fixed?
    2001-12
    St. Louis
    5,407
    Default Re: Autodesk 2010 Slows Machine
    Quote Originally Posted by guerin381817 View Post
    Are there dwg files in the folder you're looking in?
    - Try this tip on disabling digital signatures and see if it helps http://www.hyperpics.com/tipsandtricks/tips.asp?id=154
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Earth
    9,805
    ...and If Melanie's suggestion is not it... try looking for any sort of "dead" shortcuts - meaning anything that is pointed to something that isn't there any more - like non-existent network locations in "NetHood", or mapped to drive letters, or non-existent printers, shortcuts to non-existent locations, etc.
    Windows is notorious for seaching for things that aren't there way too long...
    Another test.... disconnect all network connections (i.e.: unplug the NIC, and disable all WiFi)... and test again.. if the speed improves, I would say Windows is looking for something it can't find via a network connection, or it's finding it, but just very slowly...
    R.K. McSwain | CAD Panacea |
  1. AutoCAD 2010 on 64bit Machine
    By Spenner in forum AutoCAD General
    Last Post: 2011-07-02, 11:53 PM
  2. REVIT 2010 32 BIT on 64 BIT machine
    By brentt in forum Revit - Hardware & Operating Systems
    Last Post: 2010-03-12, 10:04 PM
  3. Anyone running ACA 2010 on an older machine?
    By drysod88 in forum ACA General
    Last Post: 2009-05-12, 02:59 PM
  4. Will my machine run 2010?
    By gusaluphagus in forum AutoCAD General
    Last Post: 2009-04-17, 08:09 PM
