Thread: install 2004 autocad in new 64 bit computer
    2010-04
    Default install 2004 autocad in new 64 bit computer
    Can you tell me if I can install 2004 autocad in a new 64 bit computer.
    Randy
    2010-03
    8
    Default Re: install 2004 autocad in new 64 bit computer
    I was wondering if you ever found an answer to question?
    Can Autocad 2004 be successfully installed on a Windows 7 with the 64 bit processor? I would like to install LD 2004 as well.
    Thanks
    100 Club jonathanschade's Avatar
    2015-11
    130
    Apparently it can! Take a look at this http://forums.autodesk.com/t5/AutoCA...l/td-p/2702543
    I think there may be some settings in Win 7 that might need to be taken into consideration. I remember when we were looking into running ACAD 2006 on Vista - there were settings in Vista that needed to be set correctly before it would work.
    I know that 2004 was a good solid product, but why not upgrade to a true 64 bit program?
    Cairo - no, not Illinois
    5,069
    Quote Originally Posted by jonathanschade View Post
    ...I know that 2004 was a good solid product, but why not upgrade to a true 64 bit program?
    Why spend money if there's not up-side to your business operation? an SSD c: drive will get you a better bang - and the cost of buying a new 2012 seat is a lot more than a new pc w/ SSD. after all, there's no upgrade from 2004 -- you are just buying a new license.
    There is not an automatic benefit to running a 64 - bit program. Unless you are creating/using larger files, then the choice between 32 vs 64 bit application doesn't matter all that much.
    of course. most of my stuff is civil, with huge xref's attached, so I am lusting after a win7-64 w/ 24Gb RAM
  1. IT42-1: Using Microsoft System Management Server to Install AutoCAD 2004
    By Autodesk University in forum Information Technology
    Last Post: 2013-04-08, 06:59 PM
  2. IT23-1: Using Group Policies to Install AutoCAD 2004
    Last Post: 2013-04-08, 06:58 PM
  3. Replies: 7
    Last Post: 2012-02-07, 02:43 AM
  4. Replies: 1
    Last Post: 2007-02-13, 05:19 AM
  5. AutoCAD 2004 - Install Express Tools
    By tflaherty in forum AutoCAD General
    Last Post: 2005-06-03, 08:40 PM
