Thread: level of accuracy for contours created using google image
    2011-02
    Default level of accuracy for contours created using google image
    I wish to know about level of accuracy comparing contours created by google earth image and total station survey
    2011-02
    2
    Default Re: level of accuracy for contours created using google image
    Use the Total Station. The data collected by the total station will be far more accurate.
    Personally I would not use the Google data for design except for determining potential routes for roaways, borrow locations etc. I will not use google for anything but. The next phase to is gather Lidar or run an actual survey. Lidar data I have worked with seems to be 20cm to 80cm error when checked to total station or GPS. (Lidar gets better on hard surfaces such as ACP).
    2008-09
    23
    I also wouldn't use Google Earth terrain data for construction design but would use it for planning purposes and feasibility type research.
    2008-06
    The Yay! (Bay Area, CA)
    131
    Quote Originally Posted by mohmed.zuber535380 View Post
    it depends on how far in or out you're zoomed into the map but either way it's no good for design. I only use it for large scale exhibits as a way to get some sort of idea of the terrain that lays on top of an image or something.
  1. Created Surface from polyline contours
    By Tom.Weinstein.137333 in forum AutoCAD Civil 3D - General
    Last Post: 2012-10-26, 02:15 PM
  2. Export to Google Earth, don't follow contours
    By Eric Stewart in forum Revit Architecture - General
    Last Post: 2012-03-08, 08:45 PM
  3. contours from Google earth
    By sanrajbhar677632 in forum Geospatial - General
    Last Post: 2011-12-10, 08:03 PM
  4. Google Image and surface
    By Scott_Haynes in forum AutoCAD Civil 3D - General
    Last Post: 2009-05-08, 06:10 AM
  5. Image file export- accuracy and quality
    By ron.sanpedro in forum Revit Architecture - Wish List
    Last Post: 2006-11-14, 08:39 PM
