Has anyone ever ran into this problem. I'm in model space and have my elevations xref'd in and when I go to my "carrier sheet" in paper space the text doesn't show up. Any suggestions?
First check make sure the layer the text is on is on and thawed in that view port.
Second is the text using an annotated text style?
If it is using the annotated text, you need to add the scale of the viewport to all of the text objects.
I had the same problem after I check the Annotation scale, I still couldn't see the text, so I detached the xref and I attached again and it work...
IT Net Solutions
Devar gevil first check the text layer name.
now go to in vport. (means double click in vport)
then press LA (For layer manager)
and check the same text layer in under vpfreaze.
it will be freez in viewport. just uncheck your text will be appeal.
i hope.
